OnQuit Event
Fires while SiteKiosk is terminated.
SiteKiosk.OnQuit = handler
Use OnQuit2 to receive the shutdown mode.
The following example shows an alert window when SiteKiosk is terminated.
SiteKiosk.OnQuit = OnQuit;
function OnQuit()
alert("SiteKiosk will close");
