MessageDeliveryStatus Property
The MessageDeliveryStatus property retrieves current message delivery status.
[long=] SiteKiosk.Plugins("SitePhone").MessageDeliveryStatus
Long value that retrieves current message delivery status.
Possible status flags are:
MDS_UNKNOWN = -1;
MDS_UNDEFINED = 0;
MDS_ANALYZING = 1;
MDS_ACCEPTABLE = 2;
MDS_NOT_ROUTABLE = 3;
MDS_DELIVERY_PENDING = 4;
MDS_DELIVERY_SUCCESSFUL = 5;
MDS_DELIVERY_FAILED = 6;
If you want to react when this property changed, you can use the
OnMessageStateChanged Event.
The following example keeps a HTML element containing the message state up to date.
<div id="MessageDeliveryStatus"></div>
SitePhone.OnMessageStateChanged = OnMessageStateChanged;
MDS_UNDEFINED = 0;
MDS_ANALYZING = 1;
MDS_ACCEPTABLE = 2;
function OnMessageStateChanged()
switch (SitePhone.MessageDeliveryStatus)
case MDS_ANALYZING:
MessageDeliveryStatus.innerHTML = "Analyzing...";
break;
case MDS_NOT_ROUTABLE:
"Message delivery not possible.";
break;
case MDS_DELIVERY_PENDING:
"Message delivery pending...";
break;
case MDS_DELIVERY_SUCCESSFUL:
"Message delivery successful.";
break;
case MDS_DELIVERY_FAILED:
MessageDeliveryStatus.innerHTML = "Message delivery failed.";
break;
