OnMessageStateChanged Event
Fires when the MessageDeliveryStatus Property changes.
    SiteKiosk.Plugins("SitePhone").OnMessageStateChanged = handler
    The following example keeps a HTML element containing the message state up to date.
    <div id="MessageDeliveryStatus"></div>
    SitePhone.OnMessageStateChanged = OnMessageStateChanged;
    MDS_UNDEFINED = 0;
    MDS_ANALYZING = 1;
    MDS_ACCEPTABLE = 2;
    MDS_NOT_ROUTABLE = 3;
    MDS_DELIVERY_PENDING = 4;
    MDS_DELIVERY_SUCCESSFUL = 5;
    MDS_DELIVERY_FAILED = 6;
    function OnMessageStateChanged()
       switch (SitePhone.MessageDeliveryStatus)
          case MDS_ANALYZING:
             MessageDeliveryStatus.innerHTML = "Analyzing...";
             break;
          case MDS_NOT_ROUTABLE:
                "Message delivery not possible.";
             break;
          case MDS_DELIVERY_PENDING:
                "Message delivery pending...";
             break;
          case MDS_DELIVERY_SUCCESSFUL:
                "Message delivery successful.";
             break;
          case MDS_DELIVERY_FAILED:
             MessageDeliveryStatus.innerHTML = "Message delivery failed.";
             break;
