Enabled Property
The Enabled property indicates if the SiteRemote plugin is enabled.
[bool=] SiteKiosk.Plugins("SiteRemote").Enabled
Boolean value that indicates if SiteRemote is active.
The following example determines if SiteRemote is enabled and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteRemote").Enabled);
