SiteRemote Object
The SiteRemote object provides information about the SiteRemote plugin.
The following table lists the members provided by the SiteRemote object.
This object is available through the collection Plugins.
Use the SiteRemote object to determine if this plugin is enabled.
The following example determines if SiteRemote is enabled and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteRemote").Enabled);
