TaskbarVisible Property
The TaskbarVisible property specifies if the taskbar should be shown.
    SiteKiosk.SiteSkin.TaskbarVisible [=bool]
    Boolean value that specifies or retrieves if the taskbar
    should be shown.
    The taskbar can only be forced to be invisible. If this property is true, it will be hidden in some situations anyway.
    The following example changes the visibility of the taskbar when the link is clicked.
    sskin = SiteKiosk.SiteSkin;
    function switchtb()
       sskin.TaskbarVisible = !sskin.TaskbarVisible;
    <a href="javascript:switchtb()">switch taskbar visibility</a>
