SiteSkin Object
The SiteSkin object provides information about the current browser skin.
The following table lists the members provided by the SiteSkin object.
Objects |
Description |
Config |
IXMLDOMNode object of the skin configuration. |
StringTable |
Instance of the StringTable object of SiteKioskWindow. |
Properties |
Description |
SkinName |
Name of the current skin. |
SubSkinName |
Name of the current subskin. |
TaskbarVisible |
If the taskbar should be shown. |
Events |
Description |
OnSkinChange |
Fires when the browser skin changes. |
This object is available through the main object SiteKiosk.
Use the SiteSkin object to determine the browser skin name or its strings.
The following example shows skin information including all available skin languages.
align="center">
<tr><td bgcolor="f8f8f8">
available skin languages. Click a language to activate it.
</td></tr>
<pre>
SkLang = SiteKioskWebBrowser.SiteKioskWindow.SkinLanguages;
StrTab = SiteKiosk.SiteSkin.StringTable;
document.writeln("Skin name: " + SiteKiosk.SiteSkin.SkinName);
document.writeln("SubSkin name: "+SiteKiosk.SiteSkin.SubSkinName);
for (var j = 1; j <= SkLang.Count; ++j)
if (SkLang.Item(j).LangID == StrTab.SelectedLanguage)
document.writeln("<span id='id_sklang'>Current language: " +
SkLang.Item(j).Name + " (ID " + StrTab.SelectedLanguage +
")</span>");
document.writeln("Available languages:<br>");
for (var i = 1; i <= SkLang.Count; ++i)
if (SkLang.Item(i).Enabled) skenstatus = "";
else skenstatus = "[deactivated in the configuration]";
if (i !=1) document.writeln("");
document.write("<a href='javascript:switchto(" +
SkLang.Item(i).LangID + ");' style='text-decoration:none;'>" +
SkLang.Item(i).Name + "</a>" + " (" + SkLang.Item(i).LangID +
")" + skenstatus);
SiteKioskWebBrowser.SiteKioskWindow.OnSkinLanguageChange = OSLCh;
function OSLCh(newlangid)
if (SkLang.Item(j).LangID == newlangid)
id_sklang.innerHTML = "Current language: " +
SkLang.Item(j).Name + " (ID " + newlangid + ")";
function switchto(switchid)
SiteKiosk.LocaleManager.LangID = switchid;
</pre>
</td></tr>
</table>
