Filename Property
The Filename property contains the path of the picture file.
    document.all["id_name"].Filename [=string]
    String that specifies or retrieves the filename.
    The file must be a bitmap.
    The following example shows the Filename property when the link is clicked.
    function ShowProp()
       alert(document.all['SKPictureControl'].Filename);
    <OBJECT ID="SKPictureControl" width="100" height="100"
    CLASSID="CLSID:F5996585-1B2B-442C-8185-FCB5ABC71BE2">
      <PARAM NAME="Filename" value="c:\mypic.bmp">
      <PARAM NAME="Stretch" value="0">
      <PARAM NAME="KeepAspectRatio" value="1">
    <a href="" onclick="javascript:ShowProp();">Show Filename</a>
