SKPictureControl ActiveX Control
Control to display pictures.
The following table lists the members provided by the SKPictureControl ActiveX control.
Properties |
Description |
Filename |
Path of the picture file. |
KeepAspectRatio |
Whether to keep the aspect ratio. |
Stretch |
Whether to stretch the picture. |
Methods |
Description |
Resize |
Resizes the picture. |
This ActiveX control is available in the form of scripts that can be used in combination with SiteKiosk.
Use the SKPictureControl to display bitmap images.
To initialize the ActiveX control use the OBJECT tag and, in particular, the classID to identify the control.
Set the initial object properties between the opening and closing OBJECT tags with PARAM tags.
At a later point in time it will also be possible to access/modify these properties by means of scripts.
This control shows only bitmap pictures.
CLSID
F5996585-1B2B-442C-8185-FCB5ABC71BE2
The following example shows a bitmap image in a SKPictureControl.
function ShowProp()
alert(document.all['SKPictureControl'].Filename);
<OBJECT ID="SKPictureControl" width="100" height="100"
CLASSID="CLSID:F5996585-1B2B-442C-8185-FCB5ABC71BE2">
<PARAM NAME="Filename" value="c:\mypic.bmp">
<PARAM NAME="Stretch" value="0">
<PARAM NAME="KeepAspectRatio" value="1">
<a href="" onclick="javascript:ShowProp();">Show Filename</a>
