KeepAspectRatio Property
The KeepAspectRatio property indicates whether to keep the ratio of height to width.
    document.all["id_name"].KeepAspectRatio [=bool]
    Boolean value that specifies or retrieves the keep aspect
    ratio status.
    The following example shows the KeepAspectRatio property when the link is clicked.
    function ShowProp()
       alert(document.all['SKPictureControl'].KeepAspectRatio);
    <OBJECT ID="SKPictureControl" width="100" height="100"
    CLASSID="CLSID:F5996585-1B2B-442C-8185-FCB5ABC71BE2">
      <PARAM NAME="Filename" value="c:\mypic.bmp">
      <PARAM NAME="Stretch" value="0">
      <PARAM NAME="KeepAspectRatio" value="1">
    <a href="" onclick="javascript:ShowProp();">Show KeepAspectRatio</a>
