Resize Method
The Resize method resizes the picture.
document.all["id_name"].Resize(width, height)
width |
Long value that contains the new width. |
height |
Long value that contains the new height. |
The following example resizes the picture.
function Resize()
document.all['SKPictureControl'].Resize(200, 200);
<OBJECT ID="SKPictureControl" width="100" height="100"
CLASSID="CLSID:F5996585-1B2B-442C-8185-FCB5ABC71BE2">
<PARAM NAME="Filename" value="c:\mypic.bmp">
<PARAM NAME="Stretch" value="0">
<PARAM NAME="KeepAspectRatio" value="1">
<a href="" onclick="javascript:Resize();">Resize</a>
