Stretch Property
The Stretch property indicates whether to stretch the picture to the full control size.
document.all["id_name"].Stretch [=bool]
Boolean value that specifies or retrieves the stretch status.
The following example shows the Stretch property when the link is clicked.
function ShowProp()
alert(document.all['SKPictureControl'].Stretch);
<OBJECT ID="SKPictureControl" width="100" height="100"
CLASSID="CLSID:F5996585-1B2B-442C-8185-FCB5ABC71BE2">
<PARAM NAME="Filename" value="c:\mypic.bmp">
<PARAM NAME="Stretch" value="0">
<PARAM NAME="KeepAspectRatio" value="1">
<a href="" onclick="javascript:ShowProp();">Show Stretch</a>
