InvertDirection Property
The InvertDirection property contains information about the direction of the progress bar.
    document.all["id_name"].InvertDirection [=boolean]
    Boolean value. True if the direction is inverted.
    False if the direction is not inverted.
    Note that the progress bar may be horizontally or vertically aligned. Depending on the settings for the orientation.
    The following example shows the InvertDirection property when the link is clicked.
    function ShowProp()
       alert(document.all['id_SKProgressBarControl'].InvertDirection);
    function Start()
    <br><br><br>
    <div id="id_info">
    <a href="javascript:ShowProp()">Show InvertDirection property</a>
