ProgressMax Property
The ProgressMax property contains the value for the maximum progress, i.e. a fully displayed progress bar.
document.all["id_name"].ProgressMax [=long]
Long value that specifies or retrieves the maximum progress.
The value used here equals 100% percent of progress. See ProgressMin for the start value.
The following example shows the ProgressMax property when the link is clicked.
function ShowProp()
alert(document.all['id_SKProgressBarControl'].ProgressMax);
function Start()
<br><br><br>
<div id="id_info">
<a href="javascript:ShowProp()">Show ProgressMax property</a>
