ProgressMin Property
The ProgressMin property contains the minimum value for the progress bar, i.e. the start value.
    document.all["id_name"].ProgressMin [=long]
    Long that specifies or retrieves the minimum value.
    See ProgressMax for the value of the fully displayed progress bar.
    The following example shows the ProgressMin property when the link is clicked.
    function ShowProp()
       alert(document.all['id_SKProgressBarControl'].ProgressMin);
    function Start()
    <br><br><br>
    <div id="id_info">
    <a href="javascript:ShowProp()">Show ProgressMin property</a>
