AddRect Method
The AddRect method adds a rectangle to the window region.
    SKRegion.AddRect(left, top, right, bottom, addmode)
    left Long value that specifies the left region position.
    top Long value that specifies the top region position.
    right Long value that specifies the right region position.
    bottom Long value that specifies the bottom region position.
    addmode String that specifies the add mode.
    Possible addmodes are:
    "and", "diff", "or" and "xor".
    The following example creates an ellipse shaped window.
    mydialog.URL = "http://www.sitekiosk.com";
    mydialog.Title = true;
    dlgw = mydialog.Width;
    dlgh = mydialog.Height;
    myregion = SiteKiosk.SiteKioskUI.CreateRegion();
    myregion.AddEllipse(0, 0, dlgw, dlgh, "and");
    mydialog.Region = myregion.Handle;
