SKRegion Object
The SKRegion object represents a window region.
The following table lists the members provided by the SKRegion object.
Properties |
Description |
Handle |
Handle to the region. |
Methods |
Description |
AddEllipse |
Adds an ellipse to the region. |
AddRect |
Adds an rectangle to the region. |
AddRoundRect |
Adds a round cornered rectangle to the region. |
LoadFromFile |
Loads a region from a file. |
This object is returned by the CreateRegion method.
Use the SKRegion object to handle the new window region.
The following example creates a HTML dialog with round corners.
mydialog.URL = "http://www.sitekiosk.com";
mydialog.Title = true;
dlgw = mydialog.Width;
dlgh = mydialog.Height;
myregion = SiteKiosk.SiteKioskUI.CreateRegion();
myregion.AddRoundRect(0, 0, dlgw, dlgh, 12, 12, "and");
mydialog.Region = myregion.Handle;
