AddRoundRect Method
The AddRoundRect method adds a round cornered rectangle to the window region.
SKRegion.AddRoundRect(left, top, right, bottom, ewidth, eheight, amode)
left |
Long value that specifies the left region position. |
top |
Long value that specifies the top region position. |
right |
Long value that specifies the right region position. |
bottom |
Long value that specifies the bottom region position. |
ewidth |
Long value that specifies the ellipse width. |
eheight |
Long value that specifies the ellipse height. |
amode |
String that specifies the add mode. |
Possible addmodes are:
"and", "diff", "or" and "xor".
The following example creates a HTML dialog with round corners.
mydialog.URL = "http://www.sitekiosk.com";
mydialog.Title = true;
dlgw = mydialog.Width;
dlgh = mydialog.Height;
myregion = SiteKiosk.SiteKioskUI.CreateRegion();
myregion.AddRoundRect(0, 0, dlgw, dlgh, 12, 12, "and");
mydialog.Region = myregion.Handle;
