TemplateEnabled Property
The TemplateEnabled property indicates whether a startpage template is enabled.
    [bool=] SiteKiosk.Config.StartPage.TemplateEnabled
    A startpage template is a predefined standard startpage which can be choosen in the configuration.
    The following example determines whether a startpage has been enabled and shows it in an alert window.
    alert(SiteKiosk.Config.StartPage.TemplateEnabled);
