StartPage Object
The StartPage object provides access to the startpage configuration.
The following table lists the members provided by the StartPage object.
Objects |
Description |
TemplateConfig |
IXMLDOMNode object of the startpage configuration. |
Properties |
Description |
TemplateEnabled |
Whether a startpage template is enabled. |
TemplateName |
Name of the currently selected startpage template. |
Methods |
Description |
GetStartpage |
Returns the absolute path of a startpage. |
This object is available through the object Config.
Use the StartPage object to read the startpage configuration.
The following example determines whether a startpage has been enabled and shows it in an alert window.
alert(SiteKiosk.Config.StartPage.TemplateEnabled);
