TemplateName Property
The TemplateName property contains the name of the currently selected startpage template.
    [str=] SiteKiosk.Config.StartPage.TemplateName
    Even if no startpage template is enabled there is a currently selected template.
    The following example shows the name of the currently selected startpage template in an alert window.
    alert(SiteKiosk.Config.StartPage.TemplateName);
