StartExplorer Method
The StartExplorer method starts the windows explorer.
    SiteKiosk.StartSettings.StartExplorer()
    If the RunMode property was changed from 2 to 0, the windows explorer must be started using this method to make sure that the taskbar is visible after terminating SiteKiosk.
    The following example starts the windows explorer.
    SiteKiosk.StartSettings.StartExplorer();
