LoadFile Method
The LoadFile method loads and specifies the strings from a string table file.
    SiteKioskWindow.StringTable.LoadFile(str)
    String that specifies the string table file.
    String table files are .xml files containing strings in several languages. They are located in the main directory of the currently used browser skin.
    The following example loads a string table file from the current browser skin's main directory.
    SiteKioskWindow.StringTable.LoadFile("mystringtable.xml");
