StringTable Object
The StringTable object controls the skin language.
The following table lists the members provided by the StringTable object.
This object is available through the SiteKioskWindow main object and returned by the SiteKioskUI.CreateStringTable or SiteKioskConfig.CreateStringTable method.
Use the StringTable object to choose a stringtable file or to change the skin language.
The following example shows the first button title in an alert window.
alert(SiteKioskWindow.StringTable.LoadString(1));
