LoadString Method
The LoadString method returns one string of the currently used string table.
    [str=] SiteKioskWindow.StringTable.LoadString(id)
    Long value that specifies the title ID.
    Returns a String of the current string table.
    The following example shows the first string of the current string table file.
    alert(SiteKioskWindow.StringTable.LoadString(1));
