SelectLanguage Method
The SelectLanguage method loads the strings of a supported language.
    SiteKioskWindow.StringTable.SelectLanguage(long)
    Long value that specifies a supported language ID.
    The currently used string table file must contain the strings of the chosen language.
    The following example loads the English strings.
    SiteKioskWindow.StringTable.SelectLanguage(7);
