Workarea Object
The Workarea object contains the size of the work area.
    The following table lists the members provided by the Workarea object.
    Members
    Property Description
    BottomProperty Lower work area border.
    LeftProperty Left work area border.
    RightProperty Right work area border.
    TopProperty Upper work area border.
    This object is available through the SiteKioskUI object. Use the Workarea object to handle the work area of the window.
    The following example displays the upper border of the work area in an alert window.
    alert(SiteKiosk.SiteKioskUI.Workarea.TopProperty);
