TopProperty Property
The TopProperty Property contains the upper border of the work area.
    SiteKiosk.SiteKioskUI.Workarea.TopProperty [=long]
    Long value that specifies or retrieves the upper border.
    The following example shows the upper border of the work area in an alert window.
    alert(SiteKiosk.SiteKioskUI.Workarea.TopProperty);
