LoadDocument Method
The LoadDocument method loads a xml file.
    [obj=] SiteKiosk.XML.LoadDocument(path)
    path String that specifies the path of the xml file.
Return Value Remarks
    The returned object provides members to modify the xml document.
    The following example loads a xml file.
    xmlDoc = SiteKiosk.XML.LoadDocument("c:/file.xml");
