XML Object
The XML object provides read and write access to xml files.
    The following table lists the members provided by the XML object.
    Members
    Method Description
    LoadDocument Loads a xml file.
    SaveDocument Saves a xml file.
    This object is available through the main object SiteKiosk. Use the XML object to load, modify and save xml files.
    The following example loads a xml file.
    xmlDoc = SiteKiosk.XML.LoadDocument("c:/file.xml");
