SaveDocument Method
The SaveDocument method saves a xml file.
SiteKiosk.XML.SaveDocument(path, xmlobj)
path |
String that specifies the path of the xml file. |
xmlobj |
IXMLDOMDocument object to save. |
The following example loads and saves a xml file.
xmlDoc = SiteKiosk.XML.LoadDocument("c:/file.xml");
SiteKiosk.XML.SaveDocument("c:/file.xml", xmlDoc);
