Block Property
The Block property indicates whether to replace a blocked but already displayed page.
Boolean value that retrieves the block status.
There are two possible block types:
0 : Domain in blocklist
1 : Keyword found
If this property is true, the blocked page is replaced if it is already displayed.
The following example shows the block status in an alert window.
alert(blockedpage.Block);
