BlockInfo Object
The BlockInfo object provides information about the page blocked by the Content Filter.
The following table lists the members provided by the BlockInfo object.
Properties |
Description |
Block |
Whether to replace a blocked but already displayed page. |
BlockType |
Block type. |
ComplaintsAllowed |
Whether complaints are allowed. |
Description |
Description of the reason for the block. |
Found |
Forbidden expression that has been found. |
ID |
ID of the blocking process. |
Location |
Location of the blocked expression. |
URL |
URL of the blocked page. |
This object is available through the OnBlockURL event handler.
Use the BlockInfo object to get information about the page that has been blocked by the Content Filter.
The following example shows information about an URL if it is blocked.
alert(blockedpage.URL + " has been blocked");
