BlockType Property
The BlockType property contains the block type.
    [long=] BlockInfo.BlockType
    Long value that retrieves the block type.
    Possible block types are:
    0 : Domain in blocklist
    1 : Keyword found
    The following example shows the block type in an alert window.
       alert(blockedpage.BlockType);
