Location Property
The Location property contains the spot on the page where the blocked expression was found.
    [long=] BlockInfo.Location
    Long value that retrieves the location.
    0=URL, 1=Body, 2=Title, 3=Meta tags or Keywords
    The following example shows the location of the blocked expression.
       alert(blockedpage.Location);
