BounceCount Property
The BounceCount property contains the number of bounces per slide.
BounceSlide.BounceCount [=long]
Long value that specifies or retrieves the number of bounces.
The following example creates a BounceSlide object and starts a 2 seconds slide with 5 bounces.
myslide.StartPos = 0;
myslide.EndPos = 200;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.BounceCount = 5;
myslide.Start();
function UpdatePosition(pos)
