Effects Object
The Effects object permits creating slide effect objects.
The following table lists the members provided by the Effects object.
This object is available through the main object SiteKiosk.
Use the Effects object to create a slide effect.
The following example creates a SmoothSlide object and starts the slide.
myslide.StartPos = 0;
myslide.EndPos = 200;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.Start();
function UpdatePosition(pos)
