BounceSlide Object
The BounceSlide object handles the bounce slide effect.
The following table lists the members provided by the BounceSlide object.
Properties |
Description |
BounceCount |
Number of bounces per slide. |
Duration |
Duration of the slide. |
EndPos |
End position of the slide. |
Position |
Position of the slide. |
Rate |
Rate of the slide. |
StartPos |
Start position of the slide. |
Methods |
Description |
Start |
Starts the slide. |
Stop |
Stops the slide. |
Events |
Description |
OnStart |
Fires when the slide is started. |
OnStop |
Fires when the slide is stopped. |
OnUpdatePosition |
Fires when the position changes. |
This object is returned by the CreateBounceSlide method.
Use the BounceSlide object to define the settings of the bounce slide effect.
The following example shows the functionality of the bounce slide effect.
myslide.StartPos = 200;
myslide.EndPos = 500;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.OnUpdatePosition = OnUpdatePosition;
myslide.OnStart = OnStart;
myslide.OnStop = OnStop;
function OnUpdatePosition(pos)
function OnStart()
id_slst.innerHTML = "Status: started";
function OnStop()
id_slst.innerHTML = "Status: stopped";
switchstartend();
function startslide()
myslide.Start();
function switchstartend()
sldummy = myslide.StartPos;
myslide.StartPos = myslide.EndPos;
myslide.EndPos = sldummy;
<table border="0" bgcolor="#ebebeb" width="800" cellspacing="5"
align="center">
<tr><td bgcolor="f8f8f8">
slide effect.
</td></tr>
<pre>
<div id="sldiv" style="position:relative;left:200;">
logosrc = SiteKiosk.SiteKioskDirectory;
logosrc += "skins/Default/img/background/logo.gif";
document.writeln("<img src='" + logosrc + "'>");
<br>
<span style="color:#cc3300;" id="id_slst">Status: stopped</span>
</pre>
</td></tr>
</table>
<div align="center">
<a href="javascript:startslide()">
Start slide
</a>
