Duration Property
The Duration property contains the duration of the bounce slide effect.
BounceSlide.Duration [=long]
Long value that specifies or retrieves the duration.
The following example creates a BounceSlide object and starts the slide for 2 seconds.
myslide.StartPos = 0;
myslide.EndPos = 200;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.Start();
function UpdatePosition(pos)
