EndPos Property
The EndPos property contains the position where the bounce slide ends.
BounceSlide.EndPos [=long]
Long value that specifies or retrieves the end position.
The following example creates a BounceSlide object and starts the slide ending at position 200.
myslide.StartPos = 0;
myslide.EndPos = 200;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.Start();
function UpdatePosition(pos)
