OnStart Event
Fires when the bounce slide is started.
    BounceSlide.OnStart = handler
    The following example shows if the slide has been started or stopped.
    <div id="txt" style="position:absolute;left:450;">
    Slide stopped
    myslide.StartPos = 0;
    myslide.EndPos = 200;
    myslide.Rate = 100;
    myslide.Duration = 2000;
    myslide.OnStart = Start;
    myslide.OnStop = Stop;
    myslide.Start();
    function UpdatePosition(pos)
    function Start()
       txt.innerHTML = "Slide startet";
    function Stop()
       txt.innerHTML = "Slide stopped";
