StartPos Property
The StartPos property contains the position where the bounce slide starts.
BounceSlide.StartPos [=long]
Long value that specifies or retrieves the start position.
The following example creates a BounceSlide object and starts the slide at position 0.
myslide.StartPos = 0;
myslide.EndPos = 200;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.Start();
function UpdatePosition(pos)
