Stop Method
The Stop method stops the bounce slide effect.
The following example creates and starts a BounceSlide object and stops it at position 180.
myslide.StartPos = 0;
myslide.EndPos = 200;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.Start();
function UpdatePosition(pos)
if (myslide.Position > 180) myslide.Stop();
