CreateDirectory Method
The CreateDirectory method creates a subdirectory.
    [obj=] CDDirectory.CreateDirectory(name)
    name String that specifies the name of the new subdirectory.
    Returns a CDDirectory object representing the new directory.
    The following example creates a new subdirectory in the first subdirectory of the root directory.
    subDir = SiteKiosk.CDRecording.RootDirectory.Directories.Item(1);
    newDir = subDir.CreateDirectory("dir");
