CDDirectory Object
The CDDirectory object controls a directory.
The following table lists the members provided by the CDDirectory object.
Collections |
Description |
Directories |
List of subdirectories. |
Methods |
Description |
Clear |
Clears all files and subdirectories. |
CreateDirectory |
Creates a new subdirectory. |
Delete |
Deletes a subdirectory. |
GetDirectory |
Returns a subdirectory by name. |
Import |
Imports a file or directory. |
Rename |
Renames a subdirectory. |
This object is returned by the CreateDirectory , GetDirectory or Item method.
Use the CDDirectory object to retrieve information about a directory or to modify it.
The following example shows the number of subdirectories of the first subdirectory of the root directory.
firstSubDir = SiteKiosk.CDRecording.RootDirectory.Directories.Item(1);
alert(firstSubDir.Directories.Count);
