Delete Method
The Delete method deletes a subdirectory of the directory.
    CDDirectory.Delete(name)
    name String that specifies the name of the subdirectory.
    The following example creates and deletes a subdirectory in the first subdirectory of the root directory.
    subDir = SiteKiosk.CDRecording.RootDirectory.Directories.Item(1);
    newDir = subDir.CreateDirectory("dir");
    subDir.Delete("dir");
