GetDirectory Method
The GetDirectory method returns a subdirectory by name.
    [obj=] CDDirectory.GetDirectory(name)
    name String that specifies the name of the subdirectory.
    Returns a CDDirectory object representing the subdirectory.
    The following example shows how to get a subdirectory of the first subdirectory of the root directory.
    subDir = SiteKiosk.CDRecording.RootDirectory.Directories.Item(1);
    newDir = subDir.GetDirectory("dir");
