Import Method
The Import method imports a file or directory.
    CDDirectory.Import(name)
    name String that specifies the name of the file or directory.
    The following example imports a complete directory into the first subdirectory of the root directory.
    subDir = SiteKiosk.CDRecording.RootDirectory.Directories.Item(1);
    subDir.Import("c:/dir");
