Rename Method
The Rename method renames a subdirectory.
    CDDirectory.Rename(oldname, newname)
    oldname String that specifies the old name of the subdirectory.
    newname String that specifies the new name of the subdirectory.
    The following example creates and renames a subdirectory in the first subdirectory of the root directory.
    subDir = SiteKiosk.CDRecording.RootDirectory.Directories.Item(1);
    newDir = subDir.CreateDirectory("dir");
    subDir.Rename("dir", "newdir");
