RequestConnection Method
The RequestConnection method tries to connect to the Internet using a dial-up connection.
[obj=] SiteKiosk.Dialup.RequestConnection(reason, wait, noidlereset)
reason |
String that specifies the reason for the request which will be listed in the logfile. |
wait |
Boolean value that specifies if SiteKiosk waits for the connection before the next script command is executed. |
noidlereset |
Boolean value that specifies if the connection is closed directly after revoking the connection cookie. |
Note that all modal requests (wait=true) will be terminated when SiteKiosk commits an internal logout. If you want to keep the connection alive after logging out, wait must be false.
The following example connects to the Internet.
mycon = SiteKiosk.Dialup.RequestConnection("reason", false, true);
